Will Superglue melt styrene?
Started by Mike Scott, January 27, 2024, 12:46:35 AM
I understand that Superglue doesn't work by melting things. But Superglue itself breaks down over time outdoors and is therefore not necessarily the best choice for styrene structures that are intended to be kept outside.
But why would you not use styrene cement, e.g. Testors, Revell, on syrene plastic anyway?
Jim Bertges
No, super glue will not melt styrene. It's curing time can be accelerated with the use of an accelerator (surprisingly) which generates enough heat to blister your skin, but it won't melt plastic. Do you want to melt styrene or avoid melting it?
Quote from: Jim Bertges on January 27, 2024, 02:38:48 PM
Avoid. I have a styrene kit that a part needs reattached and I don't have any model glue. Didn't wanna do something stupid and ruin it. I know they use it on resin kits but wasn't sure about styrene.
Quote from: Hepcat on January 27, 2024, 12:49:37 PM
Don't have any and don't know where to get any, except online. I already have super glue and it's just a small repair.
Quote from: Mike Scott on January 27, 2024, 02:56:47 PMDon't have any and don't know where to get any, except online.
Model glue though should be available at any convenience or hardware store. Failing those, any store that sells model kits should have model cement.
Quote from: Hepcat on January 27, 2024, 03:01:11 PM
If super glue will work, I can avoid buying something I'll probably never use again.
My first choice for the last 25+ years:
The brush applicator is a godsend.
Jim Bertges
Quote from: Mike Scott on January 27, 2024, 02:52:40 PM
A small carefully placed amount of super glue should do the trick. You'll have to hold it in place for a few seconds, but it should hold. You may want to experiment with something else (say a plastic or something) to get the hang of it.
Quote from: Jim Bertges on January 28, 2024, 01:07:21 PM
Thanks!
Tom_Hering
Modelers have used super glue on plastic models for a long, long time. For some aircraft modelers, gap-filling super glue + accelerator is the preferred way to fill seams, because it won't shrink and sands the same as styrene.
Quote from: Tom_Hering on January 28, 2024, 04:41:33 PM
My problem is the leg/foot halves on my MotM Creature have opened a little and it falls off the base. Just need to glue that shut and glue it to the base.
Tom_Hering
Sand or scrape the mating edges of the leg/foot halves. A tiny amount of super glue will give you a strong bond if it's applied to bare plastic surfaces. Not so much if it's applied to surfaces that still have old glue or paint on them. Clamp after applying the glue.
